could anyone tell me how to open my boot on my eb wagon
we have tried the button on the dash but it doesnt open it
we have also tried the key with no luck either .
Any sugestions would be great . Paulie
LEan up under the Bumper bar and undo the 2 10mm headed bolts that secure the latch.
You need 1/4 drive sockets and small hands.
You may need to inspect one at the wreckers to see what you are chasing.
once undone, you can then rectify the problem, and go throught the painfull process of lining it back up...with the bar on....or do it easy and pull the bar off.
Jas
I've got a 1991 EB S Station Wagon and I could not lock the boot.
I had to remove the assembly that holds the licence plate off to inspect.
All it was was the arm that goes from the electronic locking machine to the key hole had popped off its clip.
Licence plate had to come off to access a bolt and the interior cover had to come off as well to access the majority of the bolts.
Hope it helps.
Cheers.
Sent from AutoGuide.com Free App
The arm Is what's covered by that black plastic sleeve 3/4 the way from where the handle is.
The mentioned clip is just below where one inserts the key.
If still, unclear, get in contact with je lady pictured in the add below. She looks knowledgable in boot related issues.?
