1 - 9 of 9 Posts
EB wagon
Hey boyz...
Today i brought a ECU for my manual conversion. Was browsing thru the wreckers today when i came across a EB2 4L manual ECU. Was wondering if this will work on my 3.9l? (if it wasnt smartlocked) Ive already put the 3.9L manual ECU in and it runs ok with the auto, want to try out a 4L tho.... any thoughts??
Also, what is the difference between the 87DA and the 90DA series of ECU's? My EB1 (with the 3.9L) was running a 90DA. Any difference in performance between the 2?? Im assuming its just on the auto ECU's because of the 4spd intro in the EA2 and the manual 3.9's use the 87DA right until the 91DA 4L. True?
Brent
Brent
feed me hey
Hi Brent,
Here are the ECU part numbers used in EA - ED
3.9 MPEFI...Manual...20...87DA 12A650 AX
3.9 MPEFI...Auto......30...87DA 12A650 BX
3.9 EFI.......Manual...40...87DA 12A650 CX
3.9 EFI.......Auto......50...87DA 12A650 DX
3.2 EFI.......Manual....60...87DA 12A650 EX
3.2 EFI.......Auto.......70...87DA 12A650 FX
5.0 SEFI......Manual...60...91DA 12A650 FX
5.0 SEFI......Auto......70...91DA 12A650 GX (SWB)
5.0 SEFI......Auto......80...91DA 12A650 HX (LWB)
4.0 MPEFI...Manual...20...91DA 12A650 AX (Sedan)
4.0 MPEFI...Auto......30...91DA 12A650 BX (SWB 2.92 axle)
4.0 MPEFI...Auto......40...91DA 12A650 CX (SWB 3.27 axle)
4.0 MPEFI...Auto......50...91DA 12A650 KX (LWB and Wagon)
4.0 MPEFI...Manual...20...91DA 12A650 LX (Wagon)
With Immobilisation from 10/92
4.0 MPEFI...Manual...B2...91DA 12A650 AX (Sedan/Wagon)
4.0 MPEFI...Auto......A3...91DA 12A650 BX (SWB 2.92 axle)
4.0 MPEFI...Auto......A1...91DA 12A650 CX (SWB 3.27 axle)
4.0 MPEFI...Auto......A2...91DA 12A650 KX (LWB and Wagon)
*5.0 SEFI....Manual...D1...91DA 12A650 DX
*5.0 SEFI....Auto......C1...91DA 12A650 EX (SWB)
5.0 SEFI......Auto......C3...91DA 12A650 JX (LWB)
4.0 MPEFI...Manual...20...EDTVE 12A650 A (Tickford SS Sedan)
4.0 MPEFI...Manual...B9...92DT 12A650 AX (Tickford Sedan XR6)
4.0 MPEFI...Manual...AA...93DT 12A650 AX (Tickford XR6 Wagon)
4.0 MPEFI...Auto......B9...92DT 12A650 BX (Tickford Sedan XR6)
4.0 MPEFI...Auto......BA...91DA 12A650 BX (Tickford LWB and Wagon)
5.0 SEFI......Manual...D9...92DT 12A650 CX (GT)
5.0 SEFI......Auto......C9...91DA 12A650 DX (GT)
The last letter 'X' can be substituted for any other letter. The ECU code is displayed at the start of the ECU running test. NOTE SERIES 2 EA MODULE PREFIX IS 90DA
* Denotes EB XR8
You can use the 4.0 manual ECU on your car but theres no way of physically telling if its Smartlock. Plug it in and if it goes then it isn't
boosted sleeper
You been doin ya homework there NZ?
You have got a lot of time on your hands Karl!
Sundeep
feed me hey
Took me like 2 hours to type that and get it lined up properly, hence the full stops. It deletes multiple spaces for some reason:priest:
EB wagon
Discussion Starter · #6 ·
I got all that Karl...
What i need to know is if the 87DA 12A650 AX is the same as the 90DA 12A650 AX? Was there a 90DA version for the manual MPI 3.9L?
Brent
EB wagon
Discussion Starter · #8 ·
Cool, thanx kyle ;)
Brent
1 - 9 of 9 Posts
