Sandwich Connoisseur
Can anyone tell me step by step how to remove the rear bumper off an ed? I've got a small dent in the grey plastic I've got to knock out. Thanks.
Donno
If the dent is in the plastic there is no way to push it back out. You will have to repair it with some form of plastic repair, I just use Dominion plastic filler its really flexible and sticks better than conventional filler.
But to undo the rear bar you need to:
~Remove the towbar if you have one
~Remove the 6 phillips screws in each wheel arch (3 each) holding the mudflaps and at the top.
~Remove the 4 (2 a side) 13mm bolts in the boot floor in front of the tail lights.
~Then slide the bar back off the clips.
Installation is the reverse.
