1 - 16 of 16 Posts
Australian Fairmont Member
Hi all.
Taken the plunge. Have been looking at all the angles for the last 3-4 months to do up my EA Ghia. Have spent all the money on just about everything over the last 3-4 years except the motor, gearbox - and exhaust system. Translated - definitely attached to the ol' girl and definitely do not want to abandon her. So the comments along those lines aren't needed - unless they are seriously high on the comic factor.
Long story short - have got my hands on a donor ED (early 94 - front end damage - motor safe though) - with 100 000 on the clock (nice and low). The plan is to replace items on the Ghia with the following from the ED - the motor, gearbox, computer, tail-shaft, diff, calipers&rotors and other minor items.
Only foreseeable downside is that I will be giving up the LSD (but a recent worsening back end 'wobble' tells me either I have very bad rear rotors or a suggested possible bent axle is possible) - and having to play around with getting speedos and trip computers right.
If anyone else can see any problems (besides a lot of work) - feel free to offer advice. Though not out of my depth - reassurance I am doing the right thing would be handy :).
Also dropping in a 2.5" exhaust system, extractors, improved air intake and the much talked about off the shelf cam from Crow. Just fyi in case people were wondering what else was planned.
That raises a question - I have spent the last 3-4 on and off in the US where a lot of people gut their cats (not the 4 legged variety) - any stories of people doing that here is Oz??? Not definitely going to do it - just thinking about it 5%
Later and thanks for any input on the above.
Crazed Cone Chaser
If you throw in the whole diff from the ED you could probably stick the LSD Carrier from the EA into it, thats is unless that Carrier is stuffed.
Most of the guys here are against gutting cats due to the dangerous emmisions that get produced as a result.
P1mp Daddy
I would love to do that... but the other way around.
Ive got an ED futura and want all the fairmont ghia accessorys in my car :)
I got stuck on the door trims and the power windows...
If i remember from the wreckers, the fairmont trims fit no probs, but if you want power windows it looks like a *****.
If you know your stuff, then go for it, basically rips the the trims out and all the lectronics.
my $.02
Do you have an EA series 1 or 2?
If its a Series 2 there wouldnt be much point in swapping the Auto, cause they are basically the same. Keep it for when the current one dies. Same goes for the rotors and calipers, unless yours are rooted.
I try to find out where that back end wobble is coming from before swapping stuff like diffs and driveshafts when it could be just an out of balance wheel.....
And leave the Cats alone, the environment is bad enough already, and youd be lucky to gain 5kw anyway(if the cat is in good working order) And without them they can make the car sound like **** too...
Just a thought
How badly damaged is the ED? Why not consider putting all the Fairmont Ghia stuff in the ED?
Discussion Starter · #6 ·
She is too bad for that...
Thanks lads,
As for going the other way - EA ghia into the ED - front right side as you are looking at the car. Strut tower area is right in and up against the plenum and so forth. Radiator area, lights and everything in that area are completely gone or definitely not salvagable. Translated - if I had a front cut - yes. Without it - big probs.
Good idea though if it was possible - the extra body rigidty of the ED over the EA would be a nice bonus.
As for the other post - it is a Series 1 - so it is the ol mechanical 3 speed. Even with the 2.77 diff - she rides along at around 2700 - 2800 revs (far too high) on the highway at 115 to 120 clicks; one of the big reason for changing the box. Looked at a T5 to drop in - but more trouble that it is worth - unless I could find it on the donor car. Not impossible but hard. Other big reason for the change is I have 350 thou on the EA - only 100 thou on the ED.
Yes - need to do the rotors and so forth - need a regrind at best; at that age they may be getting a little low. Will keep the calipers in reserve though come to think of it.
As for the cats - good to see the feedback on this. I was suprised at the guys who do it in the US, and was really just throwing it out there. Glad to see people replying to this are not vandals. Haven't heard anyone doing it here (as in physically hear the exhaust note) - so to hear from one of you that it sounds like sh.. helps also.
As for the rear end and other probs - Springs and shocks are under 2 years old. Brake pads were done 12 months ago and a few other things like urethane bushes on most things. The tyres are less than 2 months old as well (225/60's). So the only thing I had left on the list for the rear end was the rotors needed machining or the dreaded fact the axle had started to go - know two others in the last couple of years who had this problem.
Speaking of the diff - seeing as I drive a lot of highway clicks - would the 2.77 diff setting still be okay with the 4spd slush-box - or would it really be that slow?? Remember, I ain't looking for a "straight line tyre chewer" - just something with a bit of poke, nice exhaust note - and big long legs on the highway. Legs on the highway is very important :).
Thanks for the info on the carrier for the LSD as well - like most things - something that hadn't cossed my mind. Anyone with experince on doing this??
Thanks for the advice one and all - got 'worried' when the first one I saw was the signature that said something about the "size of a man is the size of his toys" or something like that. I thought great - here I go getting beaten up by the guys with 8 cans instead of me with 6 ;).
Later good people - anyone with any foreseeable problems for me to avoid or overcome - feel free to add.
Rail Rider
One word...Smartlock!
Smartlock is intergrated into the ED, door locks, boot release ignition lock, CPU.
Can be done but it will take alot of time possibly money too!
I would say ge yourself a FORD Bible (workshop manual) not a gregory's one, one that the ford machanics have got. will tell you every nut, bolt and wire about boths cars. Pricey though $130.
Chromed Member
i'll second that albert,
S M A R T L O C K
also
which dash are you guna use? digial EA Ghia one, or ED. Plugs to dash cluster are different i think, also radio plugs different etc.
Discussion Starter · #9 ·
Thanks for this point
Thanks for the heads up. As for the factory manual - bought it 2 months after getting the car - best damn 100 odd bucks I have spent.
Except for the cheap b.......s - I used someone else's manual for a week or so - it was everything in the one volume. I go and by the manaul as the two seperate volumes - it was wrapped in a plastic package. When I open it at home - it says there is a seperate third volume which has all gearbox info (manual and auto) and two other sections which escape me now.
Useless trivia - but cheap arse mothers....... :).
Thanks for the heads up on the smart-lock. I had better put the ol' thinking cap on with regards to this - any suggestions what I should be looking out for with the smartlock system before I start reading??
Thanks guys - appreciate it.
M........
Discussion Starter · #10 ·
and.....
Sorry botch :)
Using the Ghia dash. This is one area I know I will be having to play around with maybe. Plus there is the trip computer as well.
Funny that - someone broke into my EA Ghia back in January and stole the EA trip computer among other things. The insurance company couldn't find an EA trip computer to replace it - so they got me a far better looking black ED trip computer.
Useless trivia......
I am using the EA ghia dash.
As for radio and so on - all of the original stereo and wiring loom is no longer there. A few aftermarket units are in its place :).
Thanks mate - any advice regarding the dash?? I know my potential problem areas are the CPU and possibly the dash - advice in these area would be handy.
Thanks in advance.
Ive heard that you can disable smartlock by removing the relevant Pin on the CPU connector??
Aussie Falcon Enthusiast
Re the smartlock, I have had a US 93 Cobra EEC in my Sprint previously and it ran the car fine with pin 4 removed from the wiring side connector.
Talking to another Aussie quite some time ago on an EEC mailing list I found out that when the Smartlock module is satisified that the correct key is used to start the car it sends an activation signal through pin 4 on the ECU to let the car start. After some research with a multimeter (and oscilloscope I think) he developed a simple device to attach to pin 4 and thus get around not having a smartlock module. He wouldn't give me specifics on how it worked becasue he was planning on selling them but anyone with the right equipment and a bit of electronics nous could do the job.
So in relation to swapping an ED EEC4 into an EA if you can get around the pin 4 issue you will be fine as the Smartlock module alone handles the remote unlocking et all in EDs which wont be an issue in your EA.
Yes quite right.
The easy way would be to swap the whole lot over( I mean harness, smartlock module...the lot) so your EA has smartlock.
Otherwise use an EEC from an EB 4.0L auto without smarlock.
A better idea would be to get a wrecked V8 and swap all that stuff into it.
Pete.
Discussion Starter · #14 ·
Thanks guys
Thanks for the last three posts - all had some good points.
Just getting on here from work - off for the weekend so I won't be checking it for a couple of days. After chatting to a couple of friends last night and the posts from everyone here - it seems I can defintiely get it to work - and not so it is a 'fix-it' job either.
As for pin 4 on the module and requiring a triggering voltage of some sort - I have an aftermarket alarm/immobiliser which is fitted up together with the central locking (EA ghia). I should be able to fiddle around and find a triggering voltage off of the alarm/immobiliser that might just do the job. A second immobiliser maybe (I shouldn't be typing this before I think - probably sound like a d... when I read it later) - I have some reading to do it seems. Either way - it is managable.
Thanks for the heads up guys.
Knew it would be long before someone said stick in a V8 :). btw - once heard that you couldn't stick a V8 into the EA because it was released with one??? I thought it sounded like a load when I heard it the first time - seriously this isn't true is it ?? :)
Anyways - thanks guys,
M.........
Crazed Cone Chaser
If they aren't released with a particluar engine, you have to get an Engineers certificate for it.
Just like XF's...which is probably what I will do to mine.
Re: Thanks guys
M.........
Yeah it's a Load. All you need is the V8 K-member and the running gear and away you go. Ive done two already.
Pete.
1 - 16 of 16 Posts
