Heads
Yes I still have them
they are stud mount rockers and the heads come with guide plates All you will need to do the conversion is gaskets
and I have the Head Bolt Bushings #9680
Performer RPM Ford
Designed for 289, 302, and 351-5lt Windsor Ford engines, these direct bolt-on heads deliver maximum performance in the 1500-6500 rpm range for high performance street. high-flow 2.02" intake valves are for aftermarket pistons notched for valve clearance(if greater than .520 valve lift). Will not accept rail rockers. Ford 289-302 V8s require Head Bolt Bushings #9680 and either Edelbrock Head Bolt Kit #8552 (7/16") or stock head bolts. See chart for more specs.
Chamber Size Complete (pair) Bare (pair) Complete (single)
60cc #6022* #6021* #60229*
Performer RPM with 2.02" intake valves
60cc #6025* #6024* #60249*
Performer RPM with 2.02" intake valves machined for Fel-Pro®
Important Notes:
With Ford heads(5lt), use Head Bolt Kits #8552 (7/16") or #8553 (1/2").
Test Results with the Edelbrock Performer RPM Total Power Package...
Engine dynamometer testing was done on a Ford 302 c.i.d. engine equipped with an Edelbrock manifold #7121, Performer RPM cam #7122, Performer Series carb #1405 and Performer RPM heads #6025 with 9.5:1 compression and pump gas. The results: 367 hp at 6500 rpm and 340 ft/lbs. of torque at 4500 rpm... proven performance from Edelbrock.
