Hey guys I'm not a mechanic I just like working on my own cars and learning more about the E series Ford's.
I have a EF that has been converted to a manual that I am wanting to convert back to an Automatic.
Do I only need to swap over the gearboxes/transmissions?
Thanks
You will also need to swap the ECU and wiring harness. Also the tailshaft and perhaps the differential too (if the latter was also changed with the original conversion). Financially you would be betters off elling it and buying an automatic.
What's the code number on the ECU (Catch Code) so we can see if it a manual or auto one? The code is on the sticker that faces the guard panel where the harness plugs in so you have to take the retaining clamp off the ECU and turn the ECU around to see the code.
Compare it to this list:
4DAC - EF Falcon 94' 6cyl Manual
4DAD - EF Falcon 95' 6 cyl Manual Wagon
4DAF - EF Falcon 95' 6 cyl Manual
4DBC - Ford Falcon EF
4DBD - EF Futura 95' Sedan, 4.0, Auto, 3.08
4DBE - EF Futura sedan auto
4DBF - EF Auto
4DBG - Gli/Futura Sedan Auto
4DCC - 1994 EF Fairmont Ghia, 4.0, Auto, 3:23
4DCD - 95 EF Fairmont Wagon,4.0, Auto, 3.23
4DCF - EF Fairmont 4.0L Auto
4DCG - EF Fairmont 4.0L 3.23 auto
4DDF - EF XR8 Manual Sedan 3.23
4DED - Jan 1995 EF Futura, V8, Auto, 3.23
4DEF - 1995 Series 1 NF Fairlane V8 Auto 3.23
4DEG - 1995 EF V8 fairmont auto, 3.23
4DKF - 1996 EF ex-pursuit 5.0 Auto 3:08
4TAA - EF XR6 94' 4.0L Manual 3.45:1
4TAB - EF XR6 94' 4.0L Manual 3.45
4TAC - EF XR6 96' 4.0L Manual Sedan 3.45
4TAD - EF XR6 96' 4.0L Manual 3.45
4TBD - EF Fairmont Ghia Tickford Auto 4.0L
4TDB - EF XR6 Auto.
4TEB - EF GLI DUAL FUEL I6 (Tickford Gas)
4TED - EF GLI DUAL FUEL I6 (Tickford Gas)
4TFA - XR6 Auto
5DAA - 1996 XH ute, manual, smartlock. no central locking.
5DAC - XH Manual Smartlock 3.23:1
5DBA - XH 4.0 Auto
5DBB - May 97 XH series 1 panel van with auto, smartlock and 3.23
5DBF - XH 4.0 Auto
5DCA - EF Series II Fairmont Ghia (Tickford I6HP - 4 Speed Auto - 3.45 LSD 15" Wheels
5TAC - XH XR6 Manual
5TCA - EL Police XR6 (No Speed Limit)
5TFA - EF XR6 Auto (01/03/96)
6DAB - EL Futura I6 Hybrid Manual 3.23:1
6DBA - EL GLI 4.0 AUTO OPTION 20 WITH 3.23:1
6DBB - 1997 EL Fairmont Auto.
6DBD - 1997 EL Auto 3.08 Diff
6DBE - EL Falcon 6cyl Auto
6DDB - EL Fairmont 6 cyl Auto.
6DFC - Jan 1997 EL XR8, manual, 3.23 diff.
6DFD - 1998 series1 XR8 (lo-po).
6DJA - 4.0 Tickford, Auto, Fairmont Ghia
6DJB - 4.0 Tickford, Auto, Fairmont Ghia Revision
6DHD - 1997 EL XR8 Auto.
6DLE - 4.0L Auto (South african Export)
6DNB - EL Police 4.0L Auto
6TAC - EL XR6 Manual - 3.45:1
6TAD - EL XR6 Manual - 3.45:1
6TBB - Police Spec EL - 3.23:1
6TBC - EL XR6
6TBD - EL XR6 Auto - Revision D
6TED - EL, Auto, Tickford with GAS (6 cyl)
6TGB - EL Falcon GLI - Tickford GAS ECU revision B, 1996 model
6TGE - EL Falcon GLI - Tickford GAS ECU revision E, 1998 model
6THx = EL GT Manual..
7DYA - XH 4.0 Auto
7DYB - XH 4.0 Auto
You'll also need a auto pedal box and a auto brake pedal.
