EL Fairmont Ghia
hello all.... recently bought a 96 el fairmont ghia... just took it back to the dealership because it had a leaking radiator and hole in the exhaust... when i get it back i have been qouted from profix in adelaide... to do a full brake upgrade using benedix pads and full machinig on all disks for $380 is that good price? also pacemaker headers... mild extractors and full s/steel custon 2 1/2 in exhaust system... if i get all that done with the brakes the whole lot will cost $1400 ( brakes inclusive)... is that good pricing? also has profix got a good rep to anyones knowledge....?
thanks
If you get headers fitted, make sure the primaries are the small ones, such as the 38mm (i think) for the Pacemakers, or get Wilcats or similar. Also have the zorst fitted with a 2" pipe from the muffler back. If not, and you decide to use the 41mm style primaries, have a restrictor fitted inside the cat.
The reason for all this is that if you don't do this, and simply fit a 21/2" all thro', you will lose all your lowdown torque and "driveability". It will be great from about 2500 onwards, but who drives around at those revs all the time?
EL Fairmont Ghia
thanks heaps for the advice creature3... i am looking to get some computer work done aswell... i want to car to be very economical... say below 2000 rpm..... but above that i want all the power i can get out of it... do u think i would be alright if i went for the 2 1/4 zorst and ill check out the 38 mm primaries... thanks again for the help...
