1 - 7 of 7 Posts
Gday.
I recently bought an EL XR6 - and while trying to adjust the headlights aim came to the conclusion that someone had previously re-wired them wrong, at the moment the stronger outer lights are the primary driving lights - the inner lights come on when high-beam is turned on.
I get the feeling that the weaker inner lights should be the main driving lights - cause these were the ones that could be easily adjusted (aimed).
Could someone tell me if this is right or wrong?
Thanks guys :) - any suggestions on how I can adjust the aim of the outer (projection) lights?, there is a screw that easily raises and lowers the inner lights - but I can't see anything obvious that will let me lower the outer lights aim.
3FB Educator!
Remove the blinker and you will gain easier access to the adjuster.
7mm is the adjuster size.Hope this helps.
1 - 7 of 7 Posts
