Hi all
How do I identify the EL XR 8 .......apart from the obvious headlight surround.
I have seen 2 differing types of scoops in the bonnets of several XR's. One has three lines of flutes in each scoop which are parallel and run in lines the length of the scoop (if that makes any sense !) and the other has one oval inlet set in a similarly shaped scoop.
Were these an identifying mark of EF vs EL or is it EL Series 1 vs Series 2 ?
Also, were the tail light lenses of the EL XR 8 clear or amber ?
Thanks
Thanks
