Galaxian
62 Ford Galaxie Conv. - FE 390 - MX Transmission
Hi Folks, Gal drives fine. But got two electrical Issues. Starting is good, drive a while. Keep Parking. Want start again. Nope. Starter Engine won´t turn over, Kept Battery - a Optima Red - out to charger and found it nearly discharged. How can this happen? Even cause of Short Drivings? The GEN Light did not glow during the Drive.
Drivers Side Turn Signal only work while lights out at Day Time. When evening Cruise with Headlight and Dashboard Lights on the Drivers Side Turn Signal do not work.
Passengers Side is working. Head Light Switch defect or worn?
Olli
Load test your alternator and battery and see what voltage readings you are getting
Galaxian
Thank you - will do so...Hope it will be over 14 Volts....
The other Prob maybe can be cured by inspecting Bulb and Sockets....---will report
