1 - 12 of 12 Posts
Hi all,
I am living in Europe/Netherlands and I bought my first Ford car - Ford Focus 1.0 EcoBoost 2012.
I did complete service like oil replacement, filters etc, at official Ford dealer about a month ago, after 2 weeks of driving my oil lamp started flashing and got an engine failure while driving on a highway.
Road assistance did reset the computer errors so I can bring the car to the same official Ford dealer that did the service. There was a bit of drama for two days but at the end they said that the oil injection in the engine is broken (basically I drove the car without oil or something) and the engine needs to be replaced completely, cost of ~ 6000$ in total.
Anyway, this is my first Ford car ever and I am really happy with it, but I don't know too much in deep about ford engines so I want to ask you ford fellas about this model.
I was told that parts of this model of engine cannot be repaired i.e the oil injection set and the whole engine needs to be replaced.
I am not sure if this is correct, kinda refuse to believe in it ? Can someone shed some light if he/she knows more about it? :)
Thanks in advance.
Best,
Angel
So much wrong with this , but hard to advise without all facts .Not knowing what fault codes road assistance found doesn't help either .Seems strange they cleared codes with an oil light on and let you continue driving as does the fault developing shortly after an oil and filter change .That car has been subject to many engine failures , updates and recalls .One of the recalls was for engine failure due to the degas pipe causing coolant loss due to leak but other problems also .This resulted in many repairs and engine replacements being carried out under warranty . That's a lot of money to have to lay out for repairs but not uncommon .This site in the UK lets you check out any recalls and updates but not sure if it will work in the Netherlands .If you could get a written report and more details on what caused the failure , it may help you in getting some contribution from Ford towards repair costs though maybe unlikely due to year .
https://www.ford.co.uk/owner/my-vehicle/safety-recalls
I was busy dealing dealing with insurances and legal so far, but what I learned is that the problem is oil pressure.
Worse part is that I was allowed to drive the car with oil pressure issue potentially leading to engine breakdown beyond repair - still not sure about this one.
A so called 'third-party car expert' arranged by the insurance company needs to the determine the engine damage but I am loosing hope that it can be repaired. All I hear is that Ford does not provide spare parts.
These are the OBD errors codes I got from the road assistance service the second time when they towed the car to the ford garage.
P000A:71-6C
P00039:73-6C
:frown2:
P000A:71-6C
P00039:73-6C
:frown2:
Hi there, any update on your story? I’ve had a breakdown with my Ford Focus and the garage told me the error codes they’re getting are
P000A:71 and P132B21
same thing happened to me. Oil light flickering on and off every few minutes on highway until I stopped the car. As I was slowing down I lost all power and engine warnings lights came on...
Post is 2 1/2 yrs old and member has not been back since .
Thanks for the quick reply, the P132b seems to be a reasonably straightforward fix, its the P000a:71 that is scary...I've direct messaged him too, maybe it'll find its way to his email address...
Not sure what year your car is but when they get older they can be a nightmare , especially if out of any warranty .
Here is similar ,
Great find! it's the same guy, but a bit more insight into what became of his car. He had clocked over 100k miles on it, mine's given up with less than half that :confused:
Missed that it was the same guy !!!!!!! (y)
Discussion Starter · #12 · (Edited)
Hi,
I thought I had an edge case back then. Basically, I ended up buying a new engine.
I couldn't get to the root cause of the problem because as I was told these EcoBoost engines are sort of "sealed off", opening the damn thing was of a similar cost compared to having a new engine installed in the car. The company that delivered the new engine took the old one for few hundred bucks, I have no idea what they're doing with them, could be just for a scrape metal...
Anyway, I still drive the same Ford Focus Ecoboost 1.0 / 2012 despite this event.
I hope you can get some better help, but you might be unlucky like me. These engines (especially the ealier versions) seem like a Russian roulette.
Cheers,
Angel
1 - 12 of 12 Posts
