I've got '06 CV w/150K on it and it has a blown headgasket.
The block heater fell out. I fixed that and at first it ran fine...a month later it was using a bit of anti-freeze. That amount grew, and now it uses a lot.
Can the headgaskets be changed in the car? I've head both ways.
Discussion Starter #2
That dern message went before it was supposed to.
What is the probability that the heads are toast, or that it can be fixed w/just the headgaskets being changed?
The kid said it did not get hot the 1st time.
Dont think that bbn it has gotten hot since either. We drove it for 6 months before it really started to use antifreeze, and it uses a gallon in about 25 miles now.
Carry out a cooling system pressure test which should show if any external leaks and then a block test for head / gasket test . Could check thermostat for sticking and radiator for possible partial clogged up due to overheating .Might need to bleed cooling system , if so would indicate head gasket problems . More than likely you will have to pull heads and check for damage . If so better to get heads pressure tested and skimmed if o.k and needed before replacing gasket .
