·United Kingdom, Ford Focus 1.6i, 2001, manual transmission, 39K miles.
Today my engine warning light came on accompanied by a very rough
engine.
The engines attempts to maintain tick over revs, but feels lumpy as if
one or more cylinders are not firing correctly
All the obvious were immediately checked , fuel and all fluid levels
okay etc. Temperature gauge not above normal.
On gentle execration the car hesitates but is derivable - I nursed it
home at 20/25 mph
I have a cheap OBDII reader and this gives the error codes
Fuel and Air Metering
Code 0181 - Fuel Temperature Sensor A Circuit Range/Performance
and
Transmission
Code 0761 - Shift Solenoid C Performance or Stuck Off
I suspect that the transmission warning is bogus (unless someone knows
different) - the car has manual gearbox.
Would a failure of the fuel temperature sensor cause this type of fault?
Does anyone know where it is located?
Is it part of some other sensor/control?
Alan
news2006 {at} amac {dot} f2s {dot} com
engine.
home at 20/25 mph
and
Transmission
Alan
