Australian Ford Member
My EA has considerably more play on side to side movement of wheel off ground in right front wheel than left, which has effectively none. Seems to be taken up in steering links. Not talking big movements in steering, maybe 1/8 to 1/4 inch max movement in rod, but feels a lot more when moving the wheel side to side. Have just had dynamic alignment and camber caster kit proefessionallyfitted and nothing was said about it by fitter. Should I look into it further?
Shh i'm huntin more power
You'll find it will more than likely be the inner tie rods. You can get these from bursons, but i dont like changing them as they are in the rack. I've always prefered to change the whole rack that way you know everything is right....
