Well, I have a 1990 Ford F150 with a 5.0 in it and can not get it to run right. When I put it in gear to stalls and it is pouring gas out the exhaust. I have put a new coil, plugs, plug wires, distributor and cleaned the throttle body oh and changed the TPS. The vacuum runs 25 are 26 at ideal and I have not found any bad vacuum lines. I am getting codes 22, 53 , and 54. Any ideas as the motor has 30 thousand miles on it and the timing chain is fine to double roller at that.
22
MAP (vacuum) or BARO signal out of range - MAP
53
Throttle Position sensor too high - TPS
54
Intake Air Temperature (IAT) or Vane Air Temperature (VAT) signal high - IAT VAT
