If I was to put a 351windsor cam into my 289/302 with adjusted firing order,timing etc would the performance be any different if I was to put in the same spec cam with 302 timing?
Two SC 61's = trouble
Same.. No different...Except the difference in cam timing etc itself...
slikxb
Same. I think they only changed firing order to releive a bit of stress on one of the mains caps (#2 off memory). Whether it made any difference or not, who knows.
B
more ex duration on 351 grind (not much diff), intake events are earlier (from memory) changed firing order from banging no1 cap to no5 with two consecutive pulses, makes car drive much the same, know guy w 289, 351w cam 2bbrl.
I thought the performance difference was in the altered firing order of the 351 windsor , not the Factory grinds between the two...Am I wrong???? My brother had a 302 Windsor with a mild 351 Windsor Camshaft....combined with 4-Barrell Holley and Extractors on a basically stock Engine , It went well.
