Could anyone direct me on how to find the PCV valve in my focus 2000 SPI engine. I have a poor ideling and they told me it may be the PCV valvle that needs to be changed...anyways it is time for it to be changed @>110$Kms...
I was confused by all the tubes coming out from the crankcase..I know it is somehwre around there but not sure which tube exactly...detailed description and/macro picture would be of a great help...Thanks you guys!
Discussion Starter #2
I finaly found it! for interestees...it is located on the top right of the crankcase (if you look from the above of it),,,it is the plsatic black valve between the crankcase and the vent tube...to remove it juste unplug the tube and twist the valve colckwise to pull it out...as easy as that!
