I would like to modify the light switch on my 2000 Larriat so I can use the foglights without the headlights. Larriat4wd posted some links in 2001, but they no longer work. Can anyone help me get the info I need to modify my switch?
Houston, Texas
I'm not sure if this will help or not.......
Any reputable after-market (performance, 4X4, tint, alarm) should be able to professionally install a switch and wire it for you.
You may run in to a little bit of cost when they have to run wiring but, your results will be worth it.
Eric Y.
