what up,
I'm selling my Sony Mobile ES 4-channel amp model XM-3546. I bought it last summer. To see a pic and specs check out these links:
http://www.autoinferno.com/Merchant/merchant.mv?Screen=PROD&Store_Code=01&Product_Code=101
http://www.nortek.net/Entert_sub3/audio/sony_12v/xm-3546.htm
If the links don't work for any reason heres the specs:
35Wx4 Ch, 4 Ohms at 0.04% THD (12V)
50Wx4 Ch, 2 or 1 Ohm at 0.1% THD (12V)
130Wx2, 4 Ohms at 0.1% THD (14.4V)
Discrete FET Predriver Stage
Discrete Final Stage with MOSFET Audio Devices
Regulated MOSFET Power Supply
Spontaneous Twin Drive
40Hz 0 to +12dB Low Frequency EQ
50/80Hz Lo-pass Filter, 80Hz Hi-pass Filter
Fully 1 Ohm Stable
Balanced Input Circuit for Noise Isolation
Detachable End Caps Conceal Wiring
Cooling Fan with DC Brushless Motor
The amp is in perfect shape and the old style mobile ES amplifiers were quality amps. The only problem is that to this day I have not been able to figure out how to attach the end-caps! Not a real big deal, maybe you'll have better luck. Other than that it's a great amp, and I've never had any problems with it.
Make me an offer.
--Agent
