As you can see from the pictures, the timing marks on the chain have moved from whenever I timed it.
I followed the normal timing procedure and then turned the crankshaft a few times. Every time I turn the crankshaft the color links get further away, but as you can see, they are the same number of links off on the cams and on the crankshaft.
Is this just normal, or am I missing something?
