Hi all.
Ive got an old Ford E-250 7.3L V8 Club Wagon. The problem is that since some time Ive had the problem of air entering the diesel filter. That again has the effect that if I dont do anything the engine will crank according to how long the car has not been running, to pump out the air in the filter I guess. Ive replaced the part of the fuel return line (which goes to the fuel tank) that connects to the filter and to the fuel return system above the cylinders with a hose I can look through, so I see how the diesel slowly recedes from the filter and air goes down the hose. When I put a clamp on that hose the engine will start normal.
My problem is I havnt been able to pinpoint where the air gets into the system. Ive noticed that some diesel seems to leak now and then, and found that it drops down from the starter, which is on the front right side of the car. Ive followed it up, but there the engine block starts and theres already lots of "wet stuff" there, which Im not even sure is supposed to be there...
So, has anyone here experienced something similar or heard about? Also, is there the engine (as shown on the pictures below) supposed to be that "leaky"?
Leaky engine?
Engine 2
Where it drops
Another angle
Thx in advance,
Dio
Leaky engine?
Engine 2
Where it drops
Another angle
Thx in advance,
Dio
