Ford escape 2009 driving on highways and shaking going uphill 75mph or sometimes shaking going 75mph no matter what and I also notice when it happens that my air conditioning seems to not work at 100% compacity. Once the car stops shaking, my ac kicks back up and goes 100% back full compacity. What is this? Thanks!
If it were just the shaking at ertain speeds, I'd say wheel balance, bt that doesn't explain the AC. Are there any warning lights when this happens? Possibly codes being thrown?
Could check alternator output in case it is overcharging / undercharging when loaded and throwing out electrics affecting engine . That is if it is an engine fault and not as suggested a possible wheel balance / vibration related fault .But usually wheel balance would kick in earlier and you often can drive through it . Could check engine , trans mounts and check for any excessive movement at wheels .
