· Registered
Where is the symbols listed for this feature. I see when cruise control is on and the lane keeping system is on. There is a steering wheel icon or symbol on the dashboard. It is gray when not active and green when active. What does it mean when it is orange. In the center of the dashboard is a symbol that looks like the road. When cruise control is on it shows up to 4 separate lines. Otherwise it is a solid gray block. But sometimes it can be yellow. What does the yellow mean.
Also a car symbol appears on top of the road symbol. It seems to be there when a car is in front of you. But sometimes it is not there.
Where are these features documented.
· Super Moderator
Should tell you all the info you want in owners manual / handbook if still supplied nowadays or available to download . Easiest thing to do would contact your dealership with all your questions where the salesman should usually have run through the controls and options when taking delivery of vehicle
· Registered
Thank you for the response. I did find the information in the user guide. If you know what an icon or symbol is called you can find the information. I did not know that the graphic I was interested in was call the overhead vehicle graphic. I found this information by using the search feature in the pdf viewer. I searched for the word yellow. Was able to find the information on page 277. I searched for the word amber and found the information on pg 252.
