By din tools, do you mean the removal tools that fit into the two holes on either side of the receiver? If so, I couldn't find them either...seems that parts houses only keep a couple in stock to keep overhead down. I made my own using some fairly large, stiff wire. I've heard of other people using coat-hanger wire, but I think it would be a little too flimsy. I used wire approx. the same size as the holes. I bent it into 2 "U-shaped" pieces, then inserted them and simultaneously pushed them to the outside sides of the receiver. After that, keep the outside pressure and pull the stereo out. I used pieces of wire that were about 2.5 times the length of my hand...so that when bent into a U, gave me a good handle. :driver:
