F
I have a 1994 Ford Escort and i need to change the steering wheel but i have airbags. does anyone know a way to remove the steering wheel with out the airbag going off and smacking me in the face? Please help.
Freesubway
View this thread: http://www.carstalk.net/viewtopic-381304.html
Send from http://www.carstalk.net
S
Discussion Starter #2
> Freesubway
Disconnect the battery first, then wait maybe 10 minutes for the SRS capacitor
to discharge. No electric, no airbag discharge.
S
Pull the fuse for the horn in the inside fusebox and the airbag fuse in
the under the hood fusebox.
I have a 1995 Escort and I've done this lots of times.
T
It is actually very difficult to accidentally deploy an air bag unless you're
randomly probing wires with a multimeter or test light.
Disconnect the battery negative terminal. It's good practice to let the vehicle sit
for about 1/2 hour for the SRS backup supply to discharge. Remove the bolts holding
the air bag to the wheel. Disconnect the electrical connector for the air bag and
remove it from the car. Lay the air bag face up in a safe place.
If you are repairing something electrical, like checking the horn and cruise control
after you replace the wheel, it is ok to reconnect the battery with the air bag
removed. The SRS lamp will flash indicating a problem (obviously). Just disconnect the
battery for 1/2 hour prior to reinstalling the air bag.
H
Just disconnect the battery for a bunch of minutes and be careful.
Don't rush, it's easy -- you will say that when you finish.
Hank
On Tue, 31 Jan 2006 05:08:23 +0100, Freesubway
