1
I only a one spark from coil while turning engine over! In order to get
another spark from coil you have to turn key off and turn engine over
again. Thank You for your help with this problem! 1941-9N-Tom
R
Discussion Starter #2
Check the fuse link going to the coil it may be bad. To test you can run
a wire from the + side of battery to the coil and than start the engine,
if it runs than you have found the problem.
Good luck,
Ron
