Before you waste a while lot of money, I suggest you stop right there and find a decent garage that handles AC in cars. When you change a compressor, you need to evacuate it into a deep vacuum, pull the oil in with the vacuum. Once in a deep vacuum (greater than 29"), hold it and confirm the vacuum doesn't go towards zer
nce confirmed, you then add your refrigerant charge. Certain vintages of AC systems may have other requirements. Certain models also don't want all of the oil in the compressor. Failure to do this properly can cause oxidation in the system, failure of the compressor, leaks, and poor performance.
Unfortunately, I've seen a lot of cars that have been improperly serviced by the "AC techs" at the garages, so ask around before picking someone because they're cheaper.
