If I remove the tub liner then the tub tray, how do you install a new tray and make sure it stays on and is safe?
Administrator
Hi Jason
The tub is bolted to the Ute chassis so you take out the liner then unbolt the tub tray from the chassis and lift it off. When replacing it this will be the opposite of removal. The new tub tray will be bolted back into position then the liner refitted and it should be as safe as before.
