HI,
New to this so please bear with (I may have parked this post in the wrong section?) I'm in the process of replacing the engine in a 2003 fiesta TDCI (flood damage, bent conrod). All ancillary parts are still functioning to the best of my knowledge. Can I get a bare engine, ( like for like ) ie. F6JA and use the original engines ECU? or do I need to get the ECU from the donor engine? (if I can't use the original and cant get hold of the donor cars ECU is there a workaround for this?)
Thanks in advance
CSW
If you get the same generation, yes. In the US, you can typically get a a bare block, a short block (everything below the head gaskets but above the oil pan), and a long block (everything but the fuel system and intake).
