Status
Not open for further replies.
Ford Probe Base/ SE/ GT/ GTS 1993-1997 Specifications.
Information from Ford
Photo by Consumer Guide Automotive
Photo's by Global Auto Index
1994 Ford Probe GT
1997 Ford Probe GT
1997 Ford Probe GT
Notice the side marker left of the front wheel and the clear lens. This is a Australian Ford Probe GT.
Base and SE Model
Engine: I-4 16V DOHC 2.0L ( 122cu.in.)
115 hp @ 5500 rpm and 124 lb.tq. @ 3500 rpm ( 1993 only ), 118hp @ 5500 rpm and 127 lbtq. @ 3500 rpm ( 1994-1997 ).
Compression Ratio: 9.0:1
Fuel System: Multi-port fuel injection
Transmission: Manual/ 5-speed, Automatic 4-speed electronic w/ overdrive.
Drivetrain: Front-wheel drive
Body Type: Unitized w/seperate front subframe
Front suspension: Independent MacPherson struts
Rear suspension: Independent MacPherson struts
Steering: Power rack-and-pinion, 17:1 overall ratio
Brakes: disc/drum,power assist, ABS opitional
Wheels: Base: Steel 14x6, SE: Aluminum 15x6.5
Tires: Base: 195/65R14, SE: 205/55R15
Fuel Capacity: 15.5 gallons
Wheelbase:102.8"
Length: Base: 178.7", SE: 179.5"
Height: 51.6"
Width: 69.8"
Front Tread: Base: 59.8", SE:59.4"
Rear tread: Base :59.8", SE 59.4"
Front head room: 37.8"
Rear head room: 34.8"
Front leg room: 43.1"
Rear leg room: 28.5"
Front shoulder room: 52.0"
Rear schoulder room: 53.9"
Cargo Volume: 18cu.ft. " With rear seat backs up"
Passenger capacity: 4
1993-1997GT and 1997GTS Model
V-6 24V DOHC 2.5L (153 cu.in)
164 hp @ 6000 rpm and 156 lbtq @ 4800 rpm ( 1993 only )
164 hp @ 5600 rpm and 160 lbtq @ 4800 rpm ( 1994-1997 )
Compression ratio: 9.2:1
Fuel system: Multi-port fuel injection
Transmission: Manual/5-speed, Automatic/ 4-speed electronic w/overdrive
Drivetrain type: Front-wheel drive
Body type: Unitized w/seperate front subframe
Front / Rear suspension: Independent MacPherson struts
Brakes: disc/disc, power assist with ABS
Wheels: Aluminum 16x7
Tires: GoodYear Eagle VR "Gatorback" 225/50VR16 91V
Wheelbase: 102.8"
Length: 179.5"
Height: 51.6"
Width: 69.8"
Front/ Rear tread: 59.4"
Rear shoulder room: 53.9"
Cargo volume: 18 cu.ft. "with rear seat backs up"
Passenger Capacity: 4
Status
