I just bought an used ford territory 2007 when i buy it everythings ik and used it to go to work fine i can start it and go back home but when at home it wont start, try to switch the key at ignition several times the power is the all lights electric window audio all is on when you try to starter the car its like its trying to turn on with the engine sounds but nothing happen so frustrating please help anyone thanks
Check the battery voltage with a multimeter or DC voltmeter. You may have bought a vehicle with a dead battery or failing alternator.
Thanks for your kind reply after i call RAA the suspect is the fuel gauge is not working properly as it shows gas quarterly but apparently its lower then that so when the give some gasoline from the pipe near the engine it automatically start normal so i guess the prob is solve just need to ensure to refill every time the gas is lower the quarter thank
