Not sure if this is the right forum for this post but was hoping y'all that know more about wrenching could help me. I've got a 2013 Arctic Cat 700 cc quad & it won't start. I replaced the battery & when I turn the key, I hear what I think is the fuel pump (like it used to) but then when I push the start button just loud clicking. I tried bypassing the solenoid next to the battery but all it did was send out a bunch of sparks. Connections on the battery are clean & tight. I'm thinking starter or solenoid but not sure. Any help is greatly appreciated?
To giv e you some idea on my level of knowledge on sleds, the last one I did any amount of work on was pull start and the air intake horn from the carburetor was pointed straight at the crotch of the driver. BUT, this sounds like a starter issue.
Administrator
I agree with skinner. As you've replaced battery then most likely starter. Are there any fuses that you can see to check.
