1 - 10 of 10 Posts
Hi everyone,
Does anyone have the front end alignment specs for a 1964 Ranchero? It has a 6 cylinder with manual steering.. Thanks for any help
Steve
Can you please resend the specs? I could not print them at my house lastnight and today at work when I open your reply, the specs are no longer there...
Thank you again,
Steve
Thanks Bert,
I am new to this and when I look at his message in the forum, I can only see what he wrote and I can not find where the specs are... Can you give me a idea as where to look for them?
Thank you,
Steve
Always the student
It's still there for me too, right under his post. If I can remember, I'll see if I have the info at home and see if 1965 and 1964 are the same. Probably is, but I'll check.
Thank you to everyone!!! It's what I figured, my work computor would not allow the specs to show because I am at home and I can see them just as you guy's can....
A big Thank you to everyone for all of your help
Steve
Always the student
If my book is correct, it is showing:
Caster:
Range 1negative to 1 positive, preferred setting 0
Camber:
Range 0 to 1 1/4 Positive, preferred setting 5/8 Positive
Toe in:
1/8 to 1/4
King -pin location:
7 1/8
Wheel to pivot ratio:
Inner 20 Outer 17 1/2
1 - 10 of 10 Posts
