my 98 crown vic will not start first i took the intake off and sprayed starter fluid into it. it started up and ran while spraying starter fluid into the intake but then turned off as soon as i stopped so i guess im having a fuel issue i then checked the inertia switch which is is still disabled so its not disabling the fuel pump next i changed the fuel filter and the car still will not start is there anything i should check before dropping the fuel tank to replace the fuel pump
