I've got a ed falcon xr6 thats been supercharged but its running lean so i need a fuel pump and regulator. Can anyone tell me which type i should get and what price ill be looking at for this? Its on 6 psi but the ignition timing has been retarted to fix this problem at the moment.
Ok what have you done???
The car has been tuned and is now running lean because the pump is failing????
OR
You have placed the charger on without modifying the fuel system???
If it is the later. Than you need to upgrade your injectors to atleast 24lbs (blue tops???) and run an additional inline fuel pump if you don't want to go for a larger intank pump. Leave the fuel reg alone. Finally you will need to get you fuel system reprogramed.
I am running a 9 psi powerdyne charger with 30lbs (red tops) injectors, inline pump and standard reg with no fueling problems.
OR
The charger was placed on without modifying the fuel system.
I'd prefer just to go the intanke pump as far as i can see would be easier and cheaper and do just as good of a job.
How much and where would i get those 24lbs injectors?
