Headunit Alpine CDA-7852R
* 40 Watts x 4 High Power Amplifier
* 3 Pre outs
* Sub Woofer Lever Control
* Dual Illumination
* Gold Plated PIN Jacks
* Audio Interupt In
* Detacheble Front Panel
* ISO Connector Mounting
* "MAX TUNE PRO" tuner
* R.D.S. (radio data system)
* Ai CD Shuttle Control
* CD TEXT Ready
* S. P. S. (sound position selector)
* M DAC
* BBE
* Dual Pre-Amp Outputs & Subwoofer Output with Level Control
* Wireless Remote Control Unit.
12 CD CHANGER Alpine CDH-1214
Key Features
• Ai-NET Compatibility
• 150 Disc Title Memory
• Regulated 1-Bit DAC
• High Speed, Anti-Vibration Mechanism with Dual Hybrid Dampers
• Any Angle Mounting (0° – 90°)
Add this CD changer to your Alpne Ai-NET system and you'll be able to select 12 more CDs right from the head unit. It's small enough to be installed almost anywhere, and it's extremely reliable - Alpine has the most stable mechanism on the market. It's also very fast, so you don't have to wait long while the disc's change.
Front Speakers Boston Accoustic Pro 6.5
Nominal Size: 6-1/2"
Recommended Amplifier Power: 20-400 watts
Nominal Impedance: 3 ohm
Frequency Response (3dB in car): 50Hz-22kHz
Mounting Cutout Diameter: 5" (127mm)
Mounting Depth: 2-3/8" (60mm)
Mounting Depth with Spacer: 2-1/16" (52mm)
System Type: 2-way
6½" copolymer cone woofer
Cast aluminum woofer basket
1" aluminum dome tweeter
Axis-, flush-, surface-, and angle-mount tweeter mounting kit
System-specific crossovers
Full Specs, Click Here
Rear Speakers Boston Accoustic Rally RC51
RC51 Specs:
Type: Separate
Drivers: Tweeter, Midbass
Drivers per Channel: 2
Power Range (watts): 200 watts
Imped (ohms): 4
Crossover Included: Y
Diameter Largest Driver: 5-1/4"
Sub Wolfer Rockford Fosgate 15" Punch HX2 DVC
Model RFD1215
Normal Impedence 2 x 4 Ohms
RE (DC resistance in ohms) 2 x 2.10 Ohms
RMS/PEAK Power 600w rms / 1200w peak
Sensitivity 89db
FS (Hz) 21Hz
QMS 6.81
QES 0.35
QTS 0.33
SD (Cone Area) 133 in2
VAS (Cubic ft.) 8.795
XMAX (inches) 0.44"
Voice Coil Diameter (inches) 2.5"
Mounting Depth (inches) 7-13/32"
Amplifier Rockford Fosgate Punch 400a.4
100 watts x 4 channel car amplifier (at 2 ohms)
Dynamic power rating
Mono into a 4 ohm load 220 watts x 2
per channel into a 2 ohm load 130 watts x 4
per channel into a 4 ohm load 85 watts x4
Amplifier Rockford Fosgate Punch 500a.2
250 watts x 2 channel car amplifier (at 2 ohms)
Dynamic powe rating
Mono into a 4 ohm load 710 watts x 1
per channel into a 2 ohm load 330 watts x 2
per channel into a 4 ohm load 210 watts x 2
tested to 760watts by Rockford
All items are in Perfect Condition, package comes with power cables/RCA cables/Box for 15"sub.
$2500 ono for complete package
All original boxes and manuals are available.
for further details PM me or email [email protected]
PS. if you are not interested in buying please do not post in this thread. Thanks.
* 3 Pre outs
* Dual Illumination
* Audio Interupt In
* CD TEXT Ready
* M DAC
* BBE
Key Features
System Type: 2-way
RC51 Specs:
Type: Separate
Imped (ohms): 4
Model RFD1215
Sensitivity 89db
FS (Hz) 21Hz
QMS 6.81
QES 0.35
QTS 0.33
XMAX (inches) 0.44"
Dynamic powe rating
