1 - 9 of 9 Posts
AUPS Member
Could someone please tell me where you can get GT40 heads from? and also AU XR8 throttle bodies?
i live in adelaide btw.
thanks!
The GT40 heads production was discontinued in the USA years ago and GT40 heads are replaced by GT40P & GT40X heads... GT40 heads were only fitted to EB GT & EL GT in Australia. The GT40P heads were a standard on all AU Series I & II (Not Sure about Series III) XR8's & The T series cars + and they will requier different extractors. As were to get them brand new I am not sure if there is any performance shop that sells them.
As for the AU throttle bodies ring ford unless you want a bigger performance Throttle body in which case you should ring a performance shop near you.
Two SC 61's = trouble
AU l's had E7 heads.180 kw....Even in XR8's...
345kw of V8 Windsor Power
You can get the GT40P's from Herrod Motorsport, apparently they still had 3 set's left last week. You need Pacemaker of Genie extractors and 90 degree spark plug leads to fit them to an E-series falcon.
CEO - The BSR Group
The first AU TS's got alloy GT40Y's from memory also... $2500 each from Ford spares!
Sure its each ??? $5k for heads??
i pity tha fool
^thats ford spare part pricing.. he probably meant 25,000 each.
boosted sleeper
Yes ring Herrods for GT40P's. They should fit normal pacemakers extractors but as EDXR8 said, you'll need right angled leads if you havent got them already!
1 - 9 of 9 Posts
