Mustang Cobra Member
I just bought a '97 Cobra with 20K miles from my son. It is equipped with a Vortech blower. It's temp. gauge runs over there between "A" and "L" under normal driving conditions. It just goes over there after a warmup period and kind of operates out of there like a normal situation would operate around mid-gauge ("R" to "M"). Of course with the A/C on it goes even higher.
It does this even without a themostat. I flushed the system and the coolant is clean and good in appearance.
On occassion the "CHECK ENGINE" light has come on.
My son says all Cobras run toward hot, and that his Ford dealer said it's due to the blower.
I do not believe either of these explanations to be the reason for the indicated high temps!
So, before I go to my local performance Ford dealership, does anyone have any suggestions as to a possible solution?
Here are some things to check
Hi,
No offense, but your son has obviously been mislead in troubleshooting this problem. And without a doubt so is the Ford Dealer. I mean what do they know about a Supercharged Cobra, I have found out from experience and lots of dollars that it isn't much.
What is happening is this. The Cobra doesn't have that much difference in the computer than any other 4.6L V-8. The cars computer is sensing that there is WAY more air being pushed into the air intake tube than normally required to operate the engine.
This "measure" of air is taken by the MASS AIR FLOW (MAF) Sensor, which adjusts things like injector opening frequency and ignition timing in order to comensate for more or less air passing through the sensor. And, if your a motorhead, you should know that if the timing is "bumped-up" too much that it will cause the temerature to rise drastically.
Now, by swapping the stock MAF Sensor for a more throaty (is that a word?) 70/75mm Mass Air Flow Sensor, the computer will sense a "READ NORMAL" amount of Air passing throught the meter and change the ignition timing accordingly, in turn, reducing your temp and saving the day. He will probablly pick up a few extra horses in the process. Also, change the thermostat to a lower temperature.
After owning two saleens ('89 and a '93) and three Supercharged cobras '95/'96/'93 (I still have the '93) I know for fact that these are top priorities to check, because if your car runs too hot and gets enough boost it will blow a head gasket faster than you can get a good jump off the starting line.
If ANY of this is news to you, and/or if it helps, please, e-mail me back at [email protected] Then I will let you in a few secrets to REALLY give that COBRA some VENOM.
Thanks,
Chris
Discussion Starter · #4 ·
ibjhb said:
Not at all sure how to fix it, but could you post a picture?? :)
Hi James:
No pictures yet. They are still in the conventional camera awaiting completion of the roll. I plan to scan and e-mail to those interested. It's black/black/black, lower 2", with 245/40ZR18's front/295/35ZR18's rear on Saleen wheels. It also has a lightbar, which of course, is only visible with the top down.
Use your imagination for now.
Discussion Starter · #6 ·
Pictures of 'VENOMUS'
The wife accidentally got a CD along with the development of our 35mm pictures, so pictures are now available.
To those interested in pictures of 'VENOMUS' (ibjhb and 66PonyStang in particular), give me a clue as to how to post them here or send me an e-mail and I'll reply with pictures attached.
