OK looked at the console.
Should be enough room, might have to make up a couple of legs to raise the handbrake assembly off the floor a bit though.
Walky - I just loosened off the bolts that hold the EA handbrake to the firewall and removed the nut on the pedal box. By loosened, I mean right to the end of the thread
Then I moved it down and across slightly so it now sits under the EL dash in about the same spot where it used to sit, but lower. I'll have to make up an extension for the pedal box bolt.
It does not get in the way of your leg while driving, however it may be an issue if you ever try to climb across the inside of the car hehe. You will find it's pretty secure even without making up the extension as it requires a little force to get it under the EL dash while still on the bolts at the back :angel:
Saved me a lot of work, I've spent too much time on that car already without taking the seat/carpet out to drill holes
