1 - 12 of 12 Posts
74 XB Fairmont
you have to run a balancer that matches the windsor snout. Even if the crank is in a clevo. You run a SVO type timing chain setup which is availble through romac.
crochunter said:
Do you have to run a svo harmonic balancer with a 4' stroker crank.
I am running a standard Ross clevo balancer with a steel outer which fits perfect.
Where the cranks differ is where the crank gear sits. the clev has a slight step up around few thou. The stroker snouts are machined for windsor gears which do not have this step which makes the gear slightly loose .
You will need three woodruff keys as well ( sbc,holden six)
Croc,if you are building from new and have had the mains honed ( highly recommended) then you may need what is called a line hone set. The upper gear is made slightly bigger and i,m sure that they come in 5 and 8 thou 'tighter' .
Here's a tricky one. We just started a mates newly completed 32 Tudor with a 302w /C4 that came completed with the rolling shell. It's running a 351 firing order and has a vibration starting at 1000rpm. Checked the flex plate and it looks ok with no missing weight. Its a 1991-1996 engine and is running a 50oz Harmonic balancer ( e4te-a3a). what else could be causing the vibration ? TIA.
Administrator
This is an old thread from 2006 and may may get better answers if you start a new thread.
Does it have an old style steel fan and if so are all the blades there.
Is it running on all eight cylinders.
Here's a tricky one. We just started a mates newly completed 32 Tudor with a 302w /C4 that came completed with the rolling shell. It's running a 351 firing order and has a vibration starting at 1000rpm. Checked the flex plate and it looks ok with no missing weight. Its a 1991-1996 engine and is running a 50oz Harmonic balancer ( e4te-a3a) what else could be causing the vibration ? TIA.
It has an electric fan so not that, yes it's running on all 8 and sounds ok. Could it have the wrong flex plate do you think ?
Administrator
I guess anything is possible.
carstechguy has a good point re balancer.
As you didnt do the engine then you wont be sure whats been done to it.
1 - 12 of 12 Posts
