My hazard lights don't work, although I will never need them, ;) ;) ;) they might have to be used if the cops pull be over for an inspection.
Anyway, when I put them on, nothing happens, and while the hazard button is activated (pushed in) the indicators won't do anything either, but as soon as the hazard button is taken out the indicators work...
Any ideas? I think it may have been due to a faulty trailer plug that shorted out..
By the way, the reason that was causing my headlights to flicker all over the place while I have the high beams on was due to the higher wattage main headlight bulb that I was using in the lights. :)
Thanks heaps for you help. !!
Falcon 2.. Ferrari 0 hehe
im guessing u got an (X)treamly (F)ukd ... with ghia interior?
check the fuse...
then the relay (if they have one)
then the switch
after that, the wiring
thats basically all there is to it
