Well about 4 months ago I had a heater hose split on me and had to get towed home. When replacing the hose the thermostat was replaced but the water in the radiator was not properly done (ie almost just water, not much time to change at the time).
This was fine until a month or so ago I noticed the temp gauge sitting higher then normal, then latly it got worse as durring long trips with air con going and hot warmer weather, the temp nedle was sitting on the 'R' for normal. So I knew I should make an effort and replace the radiator water with proper stuff. I aslo noticed it was going through the water so I filled up the resivour tank a few times.
So 2 weeks ago I dropped the water and replaced it with distilled water and coolent, but it made no difference, so I was thinking the thermostat had gone again. Today befor driving home I decided to check the water level in the tank and there was none in there again! but then I noticed down the left side of the engine block coolent had leaked down.
The leak seems to have started just from underneath the heat sheild over the exhaust. So I am wondering if its the head gasket causing the leak. When I did change the coolent I did an oil change and no visible sign of water in the oil in the pan. However the block does have a thin oil coating from a leak from the head gasket (still no noticable oil use).
sorry for the long post, but if it is the head gasket can any body recomend a brand or avg price they go for?
