Hi!
I was driving my probe yesterday but this morning when i was going to drive to work and the head lights wont go up now the lamps works.
when i tried a number of times i hear that one of the relays makes a sound and the cover of this relay is broken so i can see a spark when trying to get the lamps up.
In the owners manuel this relay is "headlight"
picture of witch relay i mean is here :
Sorry for my bad enligish!
I'm not 100% sure, but I thought they used vacuum to open the headlights and just energize a solenoid valve.
I have some more information on the problem. Former owner has done a "sleepy eye mod".
First time i see this button under the dash now after owning it nearly 3 years, however if i take the the lamps up manuelly and then pull the switch down the lamps fall down but i tried to do the same with the orginal light switch then it dosent go down.
I think when i parked the car and took the lamps down i hit the sleepy eye button with my feet when this happend.
I tried to take them up with the "retra" fuse but it dosent work either.
Pic of the switch:
Edit:
Looked over all the fuses and the relays and all works fine!
I hope u understand my english!
Had a similar problem with the 97 Probe I owned a few years back. Actually, when I bought it, the headlights didn't move at all.
Not sure if this is an official mod, but I just rigged them up in the perma-low-profile position so I never had to worry about it again. If I remember correctly, I just had to wrench the actuator into the half-open position and lock it down.
Looked better that way anyway.
NOTE: and I'm pretty sure I had to pull that actuator relay. Or was it a blade fuse? Dang old age.
