I purchased a 2016 Ford Egde with 55k miles. I purchased this vehicle in May of this year. I haven’t had to use the heater since i bought it and now i haven’t been able to get the heat to work. Every video i have seen is for a 2014 Ford egde and the controls for the heat are different. I know that older models have been able to do a quick fix by pushing the power and air button and the heat will work. Does anyone have any suggestions on how to possible get the heat to work without taking it in?
Does the fan blow cold? Is it coming from the floor vents? There's a couple of things that go into making your car warm, kinda need to know what it is doing.
The fan does blow cold air. There is airflow from the floor vents. I can hear a slight change in the air when i switch it from cold to hot. But no hot air ever blows.
Most likely you're blend door isn't working. Check your antifreeze first, though. If you are low on antifreeze, your heater core may be airbound.
