Discussion Starter · #1 · (Edited)
HELP engine won't start?
I have just brought an el xr6 (my little hatch back), just about got it on the road, and then it stuffs up :(
the other day i started it up gave it a quick rev up to 6000 rpm by accident, as the revs went down it just died and now it's not starting, its got no spark, i think it might be the alarm system, i have checked the earth in the boot, fuses in the engine bay and in side the car and they are all ok, the fuel pump works, it cranks over fine, is there anything else that could be preventing spark?
Two SC 61's = trouble
Coil, Leads,electrical as in power to coil, check battery terminals and leads off them,relays etc.Wiggle test... Does rotor in distributor turn with engine turning ? Maybe imobilizer ??? Check that nut also ....
Coil lead could be shorting across the dipstick too?
You've got to watch those plugs on the back of the coils, often the pins inside will actually slide back and not make contact, even though the plug's on....
