1 - 14 of 14 Posts
Looking in YOUR bathroom.
Ive got a K27 here but im trying to get more details on it. Wheel trim, flow curves etc.
any help at all would be appricated
There is a tag on the comp housing with
GROSSE k27 3064g11.11
ALT NR 85 577 1292
AUSF NR 5327 970 6485
Also cast into the comp housing is
2 O 154126\2531
5327 101 5091
and the Exhaust housing
5327 101 6990
GGGNICR 202
Dan
Two SC 61's = trouble
It possibly has an ar 60/68 for motor size 2.0..
Similar in size to T25...
There was a kit on E-bay having two of these for Falcon E/A-AU six.....
Discussion Starter #3 (Edited)
Chasing 500rwkw
I have done some searching cos I was bored and have found that the KKK series was made by SARD but couldnt find any info on that company in english.
All i could find is that the turbo went a some kind of porsche,
I posted your questions on the porsche section of automotive forums but no replies as of yet.
http://www.automotiveforums.com/vbulletin/showthread.php?p=1473103#post1473103
Your pics above dont work btw
that turbo is massive looking compared to the one in your pic.
Discussion Starter #5 (Edited)
pictures fixed
the K27(mine) is the bigger one btw
Hmm I did a search and thats what it came up with,but its obviously a big mother..Volvo etc use them too.. I wander if it has been hi flowed ?
YES its a 5 Speed!!
what would be an ideal secondhand turbo for a 4ltr? in regards to about 200rwkw output???
what car could one be sourced from? what price? im guessing a japanese car.... im just interested in doing something similar to the xr after the summernats experience!!! :s6:
The VG 30T is about the biggest it's around the T3 size..Early Rx7's had T4's but good luck finding one..Ring around there is often specials on GT40 series around $2200 some times cheaper..
IMO the best would be to get a RX7 series 5 turbo then hi-flow it with a V1 or H3 compressor. That should get you about 320ishrwhp. You could do the same with a VG30T but you may have to get the turbine backcut to prevent compressor surge. Also the RX7 has a slightly better wastegate setup.
There's nothing std that will do 200rwkw as a single. 2 x rb20s maybe, 2 x rb25s definitely. There is always hiflowed RX7 turbos floating around.
Go and get a garrett turbo (AirResearch) pretty hard core, roller bearing is always a good option, and the T3 is a good size, unless you want to go stoopid and get a truck turbo..
Most turbo's are rated to Garrett equivalent, so its worthwhile having a look.
Discussion Starter #13
This K27 has a T3 flange and is for sale ;) See FS forums. It will see you WAY over 220rwkw.
YES its a 5 Speed!!
sorry to hijack your thread walky... i will start a new one as i have additional questions, thanks
1 - 14 of 14 Posts
