F-250 Member
I just got a 89 ford bronco for free and its got the 5.0 and efi well it came to me with a cracked exhaust manifold so i replaced it and gave it a tune up like new plugs and oil change but for some reason it still ran ruff. well i went to clean the throttle bodies and the next morning i went to start the truck it would turn over but not start so i had the batterie and starter checked but there fine and im 18 and i need this thing fixed and im stretched on my mechanical capabilities so can someone piont me in the right direction so i can drive again thanks you guys
Multi Ford Member
Well I hope you took the throttle body off before you cleaned it. If you just speayed cleaner into the motor it will screwup the gasket between the upper and lower intake manifolds. It usually doesn't do it overnite though. If this is what happened, you probably have a flooded condition in the motor.
