HELP NEEDED WHAT CAB IS GOOD FOR MY MOTOR I Have A 302 Windsor which I have had it stroked to a 347 with A Edlebrock Performer Manifold 625cfm Demon Carb BIG HEAD WORK DONE roller rockers borded out 60 thou flat top piston with pacemaker extractors 2800 stall the car is still running 2.78 gears in the diff but soon to have fitted 3.5 lsd THE CAB I HAVE ON IS NOT DOING THE JOB NEED HELP ON WHAT CAB WILL MAKE THE MOST POWER FOR MY MOTOR HAVE NOT PUT CAR ON DYNO YET AND HAVE NO IDEAR OF HOW MUCH HP ILL WILL GET here are my cam specs Crane Cam With
Lift intake @ cam 314 @ valve 502 rocker arm ratio
Exhaust @ cam 325 @ valve 520 1.6
Open closes advertised duration
Cam timing .0042 intake 36 . BTDC 70. ABDC 286
@ tappet exhaust 81 . BBDC 35 . ATDC 296
REV RANGE MINMUM RPM 3000
MAXIMUM 6000
VALVE FLOAT 6500
MAXIMUM 6000
VALVE FLOAT 6500
