Hey y'all,
I am a very capable and self accomplished d.i.y. mechanic... My brand of choice for trucks has been GM, Toyota for sedans throughout my life. I do all my own work if I have the equipment and time, and have had very little issues over the years. However, I recently purchased 2010 F-150 XLT Rwd. The truck ran well for the first two months until I started getting a rubbing/grinding noise when I turn my wheel even an inch keft-of-center.... Of course I initially thought wheel bearing as y'all may be thinking as any half minded car person would assume. Being left of center, the weight is starting to shift to the right of the vehicle so I assumed the front passenger side. I replaced it yesterday with a brand new hub assembly, and I am still getting the noise. I plan on leaving the driver's side as well,but I'm not 100% convinced it is the hub assembly/wheel bearing..... Also, my strut assembly on the driver side is shot.... I jacked the truck up in the middle of the cross member and the passenger side was 3" off the ground while the driver side tire was still touching. I've never had a strut assembly cause this type of symptom to make it sound like a wheel bearing.... Could it be?
My last thought was maybe a caliper piston not receding all the way into the caliper and causing the pad to stick out and rub when I'm left-of-center? I just put new coated rotors on the front a few weeks ago and the lip on both had cut marks already and the inside of the passenger rorot had rub patterns when I changed the wheel bearing.
Any help is appreciated
