I have a 2000 ford focus and i am having trouble starting the car. I went out to start my car today and i turned the ignition and all it did was make a clicking noise. then i connected jumper cables and tried to start it and it actually turned the motor over but it did not seem to have enough energy to start it. so i removed the battery and charged it and i put it back in and i turn the ignition on and all the lights and electronics work but now when i turn the key it does not make any noise or attempt to start
I'm having same problem with my 2003 ford focus. I dont know what else to check since all fuses are good. Thinking maybe battery cable has to be replaced if not then I'm lost. If you figure yours out before I do let me know so I can fix mine. I'll do same for you
I think he may have got it fixed as it is a 14 yr old post .
Test your battery , check battery leads and grounds , check starter motor and wiring .
